please help!!!!!!!!!!
Ok so i started bleeding my clutch. i got some fluid out, and obviously im going to have some fluid spillage. but i have fluid leaking between my bellhousing and engine block...wtf is there suppose to be leaking fluid there beacuse of the design..it also makes some weird noise. will it ruine my clutch, should i wait till the fluid dries, i hope this is normal!!!! please help!!!!
ok the fluid on the inside of the bellhousing is ok. would it hurt anything if i sprayed some break cleaner down the hole where the bleeder nut is to clean the rest of the fluid out....if i leave the fluid there it shouldnt hurt anything right?
