Crankshaft expansion Plug Leak - with fun pictures!
Old 10-27-2008, 08:41 AM
rao
rao's Avatar
Default Crankshaft expansion Plug Leak - with fun pictures!
The odd thing is that the clutch seemed to work just fine - this is what you get after 7k miles with a leaking crankshaft expansion plug. I pulled the transmission to install a remote clutch bleeder and this is what I found.
The only symptom was a small amount of oil coming out of the bottom of the bell housing. Plus the car didn't perform as well as expected - think the oil might have caused some lower dyno numbers
The amazing thing is that the car moved at all....
For future reference - the expansion plug is 1" and the GM Part Numbers are 10044811 or 24502262 or the aftermarket Dorman 555018 25.73 MM
Old 10-27-2008, 09:02 AM
rao
rao's Avatar
Like new pressure plate:
Old 10-27-2008, 04:05 PM
98mysticZ's Avatar
i used a dorman plug from oreillys and the one i used was abit longer than the stock one gm never had it instock.... clean it out real good with brake cleaner and mix up some jb weld and put it on the outside of the freeze plug and kinda glob it on on the beveled part if u get what i am saying then hammer it in and add some more on the outside where the lip is... thats what i did on my eagle crank..... no more leaks
Old 10-27-2008, 04:54 PM
rao
rao's Avatar
Good tips, that's pretty much what I plan to do.
Old 11-20-2008, 03:34 PM
sieno1's Avatar
Default Thanx!!!!
I have an LS2 in a 1967 Corvette just pulled the tranny and found a leak, they were ready to replace the crank, and founf the plug thanx to you Thanx and ahve a great Thanxgiving!!!
Old 11-20-2008, 09:25 PM
CW00BlackTA's Avatar
That's a pretty good explanation for lower than expected performance!
Quick Reply: Crankshaft expansion Plug Leak - with fun pictures!
