pro 5.0 shifter bolts size??
Old 10-27-2008, 05:07 PM
therobman's Avatar
Default pro 5.0 shifter bolts size??
i baught mine from a member and it came with no bolts and i dont have the stock ones. mytranny didint come with a shifter im doin a m6 swap,oes anyone know the correct size of the 4 bolts
thanks
Old 10-27-2008, 05:20 PM
Bad Blue WS6's Avatar
8x1.25
Old 10-28-2008, 07:35 AM
calhoon's Avatar
The pro 5.0 bolts should be longer that the stock bolts because the base is thicker.
Old 10-28-2008, 10:04 AM
i just removed the washers on the sotckers, and used red lock tite.
Old 10-28-2008, 11:07 AM
calhoon's Avatar
There are no washers used with the stock shifter. The bolts are a flange/ washer head and are shorter than would be needed with the aftermarket shifter. If you discarded washers, you already had aftermarked bolts.
Old 10-28-2008, 11:41 AM
must be the case, I know the original owner did have a 5.0 in there as well, but when i bought it, it was back to the Hurst.
