Rebuild Question
Old 11-03-2008, 08:41 AM
Orrin's Z's Avatar
Default Rebuild Question
I got the six speed in apart Thanks alot to Graysteal M6's Write up., and fount that the 1st/2nd syncronizer keys where sheared off.
now with the questions.
Replacement part list ATM:
1st/2nd Sycronizer keys
3rd/4th scronizer keys
1st/2nd shift fork pad
Isolator cup
Now that i have it apart is there anything else i should replace?
after second craped out the gear didn't spid down i had to grind it in. was that because of the Keys or should i replace the Friction cones for 1st and 2nd?
Also from the ginding i find it hard to slide the 1st/2nd Synchronizer Sleeve on too the 2nd gear, from the grinding there is alittle lip on the gear teeth and the sleeve, can i take a little metal file and smooth that down??? or do i have to replace all that????
I can post pic's later when i get home.
Thanks in advance for all your help.
Old 11-03-2008, 09:14 AM
85MikeTPI's Avatar
Steel 3/4 fork.
Bronze fork pads on all 4 forks,
New friction kit for all synchros..
No reason to skimp on the rebuild while it's apart.
You can clean up the slider teeth with a file as long as they are not too bad. The rebuild manual has guildelines.
Old 11-03-2008, 09:28 AM
Orrin's Z's Avatar
Why steel 3/4 fork???
where is a good site to buy these parts?
Old 11-03-2008, 09:37 AM
85MikeTPI's Avatar
3/4 fork is known to bend under hard shifting. Vipers and later GM versions all came standard with them.
http://www.ddperformance.com/T-56 Parts.htm
http://www.tick-performance.com/tickshift/parts/
Do a search in this forum and you might find a few others.
Old 11-03-2008, 11:19 AM
1sick'98WS6's Avatar
The gearbox
Old 11-03-2008, 11:46 PM
davidz28man's Avatar
Default t56
hey man i would also go with some billet key ways for the 1-2/ 3-4 . also found at the gear box.
Old 11-04-2008, 09:04 AM
Orrin's Z's Avatar
yeah i was looking at the steel billet keys.
took the gears to a trany shop, they are recomending replacing the 1st, 2nd gear and syncro. dew to all the damage from the keys being broken.
