Bolts Bellhousing to Block / Slave
Old 11-04-2008, 10:06 PM
jamiesls1's Avatar
Default Bolts Bellhousing to Block / Slave
What size are they, I asked before and someone said 12x1.75x45 that was way to big.... I believe they might be a 10x1.75x45 but I would like to know for sure please help me. Also if anyone knows the size of the bolts for the slave cylinder that would be very helpful... this is a 99 camaro ls1 with a t56.
Old 11-04-2008, 10:11 PM
yamablaster024's Avatar
If I can ill look at one tomorrow. Im guessing it is a 10mm thread.
Old 11-04-2008, 11:02 PM
the_merv's Avatar
I know the Bell Housing to Block is a 10X1.5mm, and I would say about a 40mm-50mm length.
Old 11-05-2008, 02:21 AM
jamiesls1's Avatar
See I have and tried a 10x1.5x40 but it didn't want to thread in all the way in any of the holes. I am not sure if I wasn't trying hard enough to turn it but it didn't seem like it wanted to go. Maybe I should try that again but I will see what the other guy has to say tomorrow as well. Thank you guys for helping me so far.
Old 11-05-2008, 03:21 AM
Regginator's Avatar
Im not sure on the length but the threads for the slave bolts are M6x1.0
Old 11-05-2008, 11:26 AM
the_merv's Avatar
That's what I remember it was, and mine went in without a problem.
Old 11-05-2008, 01:22 PM
jamiesls1's Avatar
Ok thanks a bunch guys I will try thursday with 10x1.5 again and 10x1.75 and let you know what happens, I bet your right it is 10x1.5 for some reason I was just not checking right... thanks for the slave size too.
Old 11-08-2008, 02:36 PM
jamiesls1's Avatar
The_merv was correct. They are 10x1.5x45
Quick Reply: Bolts Bellhousing to Block / Slave
