Leaky clutch hydraulic line. Standard or special o-rings.
Old 11-08-2008, 07:02 PM
wrd1972's Avatar
Default Leaky clutch hydraulic line. Standard or special o-rings.
My flexible clutch fluid is leaking at the end where it goes into the MC. It appears that the o-rings are failing.
I have not pulled it out yet, but I need to know if they are conventional o-rings or some special kind? Where do i get replacements?
Old 11-08-2008, 07:10 PM
03 BUSA's Avatar
Have you done the drill mod? I have seen them leak because when they were drilled they got the rubber inside the hose too hot and therefore leaking around the top of the line? Just something to check.
Old 11-08-2008, 07:16 PM
BADD SS's Avatar
Gm part, they come in a pack of ten, and they are definately not a normal o-ring, almost like 2 orings sandwiched together.
Old 11-09-2008, 03:45 PM
wrd1972's Avatar
I cant locate the part number on my parts catalog PDF.
Anybody have the p/n for these o-rings?
Quick Reply: Leaky clutch hydraulic line. Standard or special o-rings.
