hyrdaulic issue?
Old 11-08-2008, 07:03 PM
vettett15's Avatar
Default hyrdaulic issue?
Hey Guys,
I seem to be having an odd issue with my clutch system. Every once in awhile I my pedal sinks to the floor and i lose fluid. It doesn't seem to be constant either, I will fill it up, check it a couple days later and it is still full then maybe a couple days after that it will randomly sink. From under the hood I checked the master and it seems fine, the line going into the tranny is dry too. The fluid does look a little dark, I also need to check where the pedal meets the master cylinder to see if it's wet there. Any suggestions?
Thanks,
Pete
