Any news on pricing of twin disc clutch/flywheel in new CTS-V and ZR1's from GM?
Wondering if anyone can find the part number and dealer cost of the factory twin disc clutches they are putting behind the zr1 and new cts-v
I have heard that the flywheel used has I think 9-bolts to match the special crank used in the LS9, so unless you have the LS9 crank as well or the aftermarket comes out with a conversion flywheel I don't think the factory twin disk will be feasible, yet.
I wish I could find some specs so I can see if the LSA or LS9 clutches will bolt up to a standard LS2 flywheel (like the LS7 clutches do)
The LSA clutch uses a dual mass flywheel and a dual disk clutch with 240mm disks. The flywheel has a 9 bolt crank pattern. The LS9 clutch uses a simpler single flywheel with a dual disk clutch that uses 260mm disks. It too has a 9 bolt crank pattern. Neither flywheel is compatible with older LSx engines that use a 6 bolt crank flange.
Andrew
Andrew
