T56 Clutch problem: Randomly pedal stiffens up and clutch starts to slip. Need help
The other day it warmed up so i took my car out and did a quick run to about 130 and held it there for a sec. I got back on the gas in 6th and it was almost like i pulled it out of gear as it revved freely. I pushed in the clutch pedal to find it was a lot harder to push to the floor then usual. After the pedal reached the floor pedal pressure went back to normal and my clutch started grabbing like it should and has been working fine since.
I had this happen awhile back too but i thought i cured it by bleeding the heck out of the lines.
My set up is a US Brake master cyl, braided an line to stock slave cyl. Spec stage 3 clutch and a fadanza light weight flywheel.
Any advice on what to look for to find the cause of this strange problem?
