ls7 clutch disc broken springs
Old 02-12-2009, 10:57 PM
scottie dont's Avatar
Default ls7 clutch disc broken springs
sup yalls i just got a ls7 clutch from a friend and when i was getting ready to install it i flipped it over to put it up on the flywheel and i heard something rattle. if your lookin at the disc you have the 4 large springs in a cross pattern. and inside them there's a smaller spring. 2 of them are loose and slide from one side to the other ( they are directly across from each other on the disc) what would cause this? and what will this effect?
i talked to a friend here and he says he wouldnt run it, i trust his word and his judgement as he has alot more experience with clutches then i do. just wanted some more opinions. thanks
- Scottie
Old 02-13-2009, 12:20 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
That is normal. Mine was the same way
Old 02-13-2009, 09:30 AM
wont that effect the pressure thats applied to the flywheel
Old 02-13-2009, 11:09 AM
Z28/2002's Avatar
Doubt it, I never had an issue with it
Old 02-13-2009, 05:10 PM
mrstage1's Avatar
Scottie, I found you.
The springs you are talking about are the takeup springs. On a street clutch the springs dampen the clutch plate so you don't get chatter when you release the clutch. Race discs often times have a solid hub without the springs. On the street a race clutch like this would be very chattery when you tried to slip it to take off.
A little looseness of the inner spring on a double setup is NORMAL. Put it in and go. It's fine unless the springs are broken or missing.
Old 02-13-2009, 09:55 PM
rollinna65's Avatar
Yep, both my LS7's have had those springs loose.
Old 08-31-2010, 09:10 AM
collins's Avatar
so a question for teh guys that have run them with the springs collapsed... does it chatter (like audibly rattling) at any point during driving?
Old 08-31-2010, 09:40 AM
6spdgto's Avatar
The above poster's springs were more than a little loose, they were completely collapsed. I have never seen this on a clutch before and therefore suggested against installing it as the LS7 friction disc that he had in the car currently didn't even have loose springs with 40k plus.
Quick Reply: ls7 clutch disc broken springs
