Pilot bearing install question...
Ok so i didnt realize to install flush until too late. Got the bearing in the crank about 1/8-3/16" past flush. Will this be ok or need to re-do?
edit for pics:
edit for pics:
HMMMM i am going to install a Pilot bearing or bushing on my 99 Ls1... Which is better a bronze bushing or a roller bearing? I read the bronze pilot bearing is better but all i could find around here is the roller bearing... Bronze is special order! Which one would you guys go with? I know i thread hijacked but it is related to the original post...
Thanks for the reply. Now i have one yes and one no. Emailed Steve from monster last night and he says definitely should come out and another re-installed. SO which is it...
If that were a bushing, I'ld go with it. Since its a bearing, I would not risk having the pilot partially ride on the needles....a sure way to cause premature wear on the bearing.
pilot bearing orientation
I am installing a Ram pilot bearing into a 383 stroker Chevy crank by Callies. One end of the bearing seems closed around the edges(I assume to keep grease from flinging out).... while the other end you can see the bearing's edge. I am not sure which end faces the transmission, and which end faces the crank. If you know, I would appreciate the help! Thank you for your time!
