LS1 T56 to LT1
Old 04-21-2009, 01:04 PM
Radcannon's Avatar
Default LS1 T56 to LT1
I have a 2002 ls1 t56 in my now totaled ta. I am looking at buying this 94 ta and I want to convert my t56 to work in it. The tranny has new master/slave clutch through out bearing, pretty much most of the mechanical components. Is there anyway to use the same clutch and setup and just swap input shafts?
Old 04-21-2009, 01:13 PM
BlueMagicSS's Avatar
You would have to switch out the bell housing as well. I'm not sure if that's the only difference or not?? Maybe someone can chime in...
Old 04-21-2009, 01:14 PM
thesource's Avatar
You need a different front plate and input shaft.
Old 04-21-2009, 01:26 PM
Radcannon's Avatar
so will I be able to reuse the clutch and pressure plate?? Since the clutch is a push style instead of pull?
Old 04-21-2009, 03:52 PM
thesource's Avatar
I am going to say no because the slave cylinder is too long thus the reason the LS1 uses a longer input shaft to begin with.
Old 04-21-2009, 04:22 PM
Radcannon's Avatar
so i would have to get a new clutch assembly? and slave cylinder then
Old 04-21-2009, 05:23 PM
Gen414's Avatar
Yep.
List of parts (I did this swap, but the other way):
Input shaft
Midplate
Bellhousing
Hydraulics
and since you are going LT1, you will also need:
Clutch Fork
Old 04-21-2009, 09:52 PM
campo's Avatar
PM sent.
Old 04-28-2009, 11:36 AM
thespeedofsound's Avatar
Originally Posted by Gen414
Yep.
Input shaft
Midplate
Bellhousing
Hydraulics
Clutch Fork
Are the bearings the same for both shafts as well?
Old 04-28-2009, 06:15 PM
Mikey 97Z M6's Avatar
Just swap the entire LS1/T56 setup into the 94. If you still have the 2002 donor car, you have everything you need to do the swap, save for the wiring modifications.
Mike
Old 04-29-2009, 04:00 PM
Gen414's Avatar
Yes they are
Old 04-29-2009, 04:03 PM
Gen414's Avatar
Mike
Wait a minute....if he does that, flywheel is different, and LS1 stuff is internal balance. I thought LT1 is external (and that part I could be wrong on, not familiar with LT1 balance, external or internal)
So, if the LT stuff IS internal, you could swap flywheels and clutch over to LS1, and use the LS1 tranny.
Old 05-06-2009, 11:08 AM
ERKEL's Avatar
Pm sent
Old 05-06-2009, 02:39 PM
Let me re-phrase that. Swap the entire LS1 engine with the LS1 T56 into the 94. He's already got a wrecked 2002 T/A with everything he needs for the engine/tranny swap. It's an easy swap.....
Mike
Old 05-07-2009, 08:12 AM
Gen414's Avatar
Mike
Ok gotcha, cool.
Old 05-07-2009, 08:13 AM
Gen414's Avatar
All PM's should be replied by now.
Old 05-11-2009, 09:41 PM
the_merv's Avatar
X2 on the complete LS1 Swap..
Quick Reply: LS1 T56 to LT1
