Putting together a clutch setup
hey guys i have a 00z...my clutch is starting to slip....i went with the ram 910hd clutch and billet flywheel now i am about to order a master and a slave....my questions are do i have to stick with ram or could i go to another brand with them also do i have to get a throwout bearing also...
any ls1 clutch will work, id recomend monster and as far as the stock slave and master, they will work fine. Just replace them with new ones. I do highly recomend a tick performance master cylinder. check ws6 stores clutches to see all your options. any other questions just pm me
almost ant throw out bearing will work...just before the install read this...youll thank me later... https://ls1tech.com/forums/manual-tr...need-shim.html
Are you saying you ALREADY bought a clutch? Or the clutch you have is the ram 910hd and IT is starting to slip?
