Squeky sounds when decelerating?
I don't know if its my clutch or not but If I am in gear and slowing down the car has a constant squeak, almost like a brake squeal but its directly under the car and somewhat near the bellhousing.
It also will make sqeaking sounds with normal driving around 1500rpm or at least thats when I seem to hear it.
Its a stock LS6 clutch from what I understand and my car makes right around 530hp @ flywheel.
Ideas?
Ideas?
If you push in the clutch and it goes away, I would say TOB. Maybe teh PB, but more than likely TOB. But, since you have to pull tranny either way, you can check/replace PB while you are there.
