master cylinder question
Old 07-14-2009, 12:23 AM
DARK98Z's Avatar
Default master cylinder question
I am going to be raplacing my master cylinder and do the drill mod. I read here that the master cylinders from a 98 are no good. If I get a new one for a 01 or 02 will it bolt on directly to my 98?
Old 07-14-2009, 01:21 PM
Honda Nick's Avatar
you've heard about the tick master cylinder?
Old 07-14-2009, 05:36 PM
4150's Avatar
01-02 clutch master cylinder is a straight bolt in, no mods needed. When my stock '00 clutch master cylinder died I replaced it with an 01-02 unit.
Old 07-14-2009, 09:35 PM
DARK98Z's Avatar
I been hearing alot of good things here about the tick master cylinder its quite expensive but its sounds like its well worth it. Im gana pass on the stock master cylinder and go with the tick master cylinder. Thanks!
