A4 to M6 (Using M6 engine harness) and M6 to A4
Old 07-16-2009, 07:01 AM
Pro52R's Avatar
Default A4 to M6 (Using M6 engine harness) and M6 to A4
Hey Guys,
Ok I've seen the write ups on how to do this.
Now...I have a guy who is swapping set-ups with me. Pedals,Console,the whole 9
We are also swapping engine harnesses, so there won't be any cutting and splicing.
My question is, on the interior harness side. I don't really care about clutch anticipation switch. (for the neutral safety,cruise,etc)
Also, since he is getting my A4 set-up. What needs to be done to his wiring harness? (on the inside)
Old 07-16-2009, 07:52 AM
Snapps's Avatar
Speartek makes an adaptive harness for the m6 to a4 conversion. It was around 225.00 for the part. I had the clutch pedal cut off since I didn't want the big old brake pedal I am use to my m6 brake pedal.
Old 07-16-2009, 08:27 AM
the_merv's Avatar
You will need to re-wire some of the interior for the Reverse Lights if you are swapping to a M6 Herness.
Quick Reply: A4 to M6 (Using M6 engine harness) and M6 to A4
