Will a LT1 pressure plate bolt to a LS flywheel?
Old 07-29-2009, 06:26 PM
52 Rat's Avatar
Default Will a LT1 pressure plate bolt to a LS flywheel?
Will a LT1 pressure plate bolt to a LS style flywheel. I have a LQ4 6.0 and a will be using a '94 LT1 T56 trans. I have a Quicktime bellhousing that will allow the trans. to bolt to the block. I'm not sure which flywheel I need to work with this set up. An advise is greatly appreciated.
Old 07-30-2009, 10:28 AM
thesource's Avatar
No its totally different.
Old 07-30-2009, 10:34 AM
the_merv's Avatar
Convert the T56 to LS Style and get that setup.
Old 07-30-2009, 10:50 AM
52 Rat's Avatar
As noted above. I have a specific bellhousing for this conversation. I need to bolt the LT1 pressure plate to the LS bellhousing. If need be I will put the flywheel in the mill and add the correct bolt circle that will allow me to use the LT1 pressure plate. I was wondering if someone have compared the two bolt circles.
Old 07-31-2009, 05:25 PM
Billy M's Avatar
LT1 Bolt circle is 11-5/8"
LS1 Bolt circle is 12-5/8"
