Recommend me an aftermarket LS7 Flywheel
In an LS2 GTO you cannot use the LS7 clutch with the LS2 flywheel. You must use an LS7 flywheel. The LS7 flywheel is totally different from an LS2. It has raised ribs on the O.D., the LS2 has none. I looked at both of them today and I don't see how it would work.
If someone has a new LS7 cluch kit, can you measure the thickness of the friction disk as sent from GM? That would be greatly appreciated.
We offer an Aluminum Flywheel for use with the stock LS7 clutch kit. Part number SC66A-2. This unit retails for $479 and is available sirectly from us or through any of our dealers. Let me know if you have any further questions and I will be happy to assist you. Thanks,
