No leak possible bad slave?
Old 08-08-2009, 01:47 AM
87GMC's Avatar
Default No leak possible bad slave?
I have a 98Z with 77k. I changed the master and try to bleed the system and still no clutch.
This is the third master i have put. When i disconnect the master the peddle is not rock hard.
My question can slave be bad with no leaks?
Possible defective master?
Old 08-08-2009, 04:09 AM
DarkJuggalo's Avatar
if its the 3rd master and still same issue im gonna have to go with the slave. i went through the same thing, i would fill the fluid, pump until my leg hurt. get **** poor if any pressure. then i found it the slave leaks internally, so you wouldnt see the leak. i would recomend changing the slave, having 3 bad masters is very unlikely
Old 08-09-2009, 01:15 AM
DVS99TRANS's Avatar
Not having the pedal rock hard with the master disconnected from the slave is unusual I think. I would have to agree that I would look into the slave though.
