26 spline
Old 08-12-2009, 09:34 PM
MJR7AD's Avatar
Question 26 spline
I have a spec 3 clutch and im not sure if it came from a t 56 mustang or what it came from, but i have a t56 from a 2000 ws6. The 6 puck clutch slides onto my 26 input spline on my transmission on the ws6, so would that mean that it will work in my car?
Old 08-13-2009, 08:26 AM
thesource's Avatar
What is the diameter of the disc?
Old 08-14-2009, 04:35 PM
NVR_SPDS's Avatar
Its not just whether or not the clutch disk will fit, it also matters if the pressure plate will bolt up to the flywheel.
Old 08-14-2009, 04:43 PM
SPEC-01's Avatar
NVR is correct. It isn;t just about the disc. Have you tried to bolt the plate to your flywheel? Do you have any pictures of the plate? If so, post them and I will be happy to identify the unit for you. Thanks!
