Replace flywheel too?
I've currently got a LS7 clutch in the car. about 60k on it, 200+ track passes over a 2 year span. Great life out of it, slipping a bit only when pushed hard at the track. I want to toss in another LS7 clutch, can I get away with the clutch/pressure plate only and a simple "resurface" of the flywheel? By simple I mean take some sandpaper and rough it up enough to force a new surface to form. Or do you think after that much abuse/wear better off with a new flywheel? If that's the case... who sells a reasonably priced kit??? Parts Taxi has it for $431 but shipping to Canada is iffy, summit is backordered for the parts $309 from summit but the flywheel is $288, but I can get the flywheel holding tool, pilot bearing, and alignment tool there too on the cheap.
I would probably go ahead and get another one just so it wont cause damage to new parts. but just wondering, I just got my first LS7 clutch kit recently and noticed that the flywheel has a raised section around the outer rim... is your like this or is it smooth all the way around?
The flywheel has a raised section. I was surprised at the pricing of the flywheel on summit, I got a kit back in 06 before kits were readilly available but I didn't spend that much on the 2 separate parts ($288 for flywheel alone???).
Well gotta order a flywheel tool now...
