Cutting factory shift stick?
Old 08-25-2009, 05:44 PM
JoeKnowsBaseball's Avatar
Default Cutting factory shift stick?
I was wondering if I can take the factory shifter stick and cut it under the little bend to make it a "short throw". I tried searching but I couldn't find anything. I'm sure the stick is solid and not hollow. And I do realize that I'd loose the threads for the ****, but I have ways of getting them back, such as an uncle that owns a machine shop...
Has anyone ever done this? Or does anyone have an opinion on it?
Old 08-26-2009, 08:25 PM
Anyone?
Old 08-27-2009, 11:08 AM
99WS6MAN's Avatar
Originally Posted by JoeKnowsBaseball
Anyone?
I'd like to know as well .. I have an extra laying around so I'm thinking of trying this out soon so if I do I'll let you know
Old 08-27-2009, 05:28 PM
ok cool man. i hate to spend $100 on a new shifter just because it's a couple inches shorter and it's shiny. can't see the **** anyways...
Old 08-27-2009, 05:45 PM
the_merv's Avatar
It's not that part that makes it a short-throw.. it's the fulcrum point in the actual shaft.. the short-shifters pivot higher a little bit, which reduces travel length.
That's from my understanding anyways..
Old 08-28-2009, 06:35 AM
calhoon's Avatar
While its true a properly made short-throw shifter has a different fulcrum point( higher) , chopping the stick will shorten it up too. Both methods will increase the shift effort.
Old 08-28-2009, 08:16 AM
the_merv's Avatar
Yea, it will.
Quick Reply: Cutting factory shift stick?
