Just ordered my Tick MC!! Cant wait!
Anyways bout to install my monster and Tick when I get it. I have heard great things about the tick MC. I am looking forward for my clucth pedal not staying to the ground everytime I power shift! lol. So How should I go about bleeding it. Should I fill the reservoir up and actuate the cylinder before installing to get it somewhat bled?
This is done by attaching the clutch line and reservior, filling the revervior, and depressing the master cylinder pushrod while pushing in the quick connect fitting with a small socket (if I remember correctly, a 5.5mm 1/4 drive socket works perfectly). Basically you want to open the quick connect with the socket, depress the pushrod, close the quick connect, retract the pushrod, and repeat. Keep the reservior topped off and above the master at all times. Doing this makes it much easier to bleed the system once the master is installed in the car.
