LT1 Flywheel Bolts Source
I searched this topic, but the most recent post referencing the issue was a bit dated.
Does anyone aftermarket make flywheel bolts for the LT1 engines, or am I limited to buying through GM?
Also, aside from my local dealer or maybe gmpartsdirect.com (which I have heard is sloooooooww to ship) is there an online source?
I need some this week. The guy I bought my swap parts from gave me five correct bolts, some with chewed heads, and one bolt that is too short because it's for a flexplate and not a flywheel.
Smaller in relation to the ARP flywheel/flexplate bolts that only fit
the older 2pc RMS GenI cranks.. They are similar to the stock sized
bolt head. This pic below (for a flexplate, so ignore the part#s) shows
the three bolts. The top is the ARP TQ-conv bolt, to the left is the stock
bolt, then below is the large ARP flywheel bolt for a 2pRMS. (No way
to fit a socket on them when installed)
HTH
mike
HTH
mike
Ordered! So painless...much better than having to call Parts Dept. of dealer, then drive there after work before they close.
Those bolts are listed as being 7/16-20, and I know when I measure the ones I have they were metric...must be an equivalent size.
Are they the same exact length, Mike?
BTW, what is "UHL?"
BTW, what is "UHL?"
BTW, what is "UHL?"
BTW, what is "UHL?"
I just double-checked a set of stock bolts, they are 7/16-20 also.. You might want to triple-check your bolts/crank-threads before running the ARP bolts in.
The ARP's are a 1/4" longer than stock, but I haven't seen any issues with the little extra length on the back side of the crank flange. (U)nder (H)ead (L)ength (UHL) is how long the shank of the bolt is.
