60mph+ vibration Need help only when off of the throttle
Got a 98 Camaro. Tick Performance 6 speed, spec clutch, cromoly driveshaft, and a 9 inch.
Just got the Tune done on the car and have been able to drive it a little. When I exceed 60 mph and let off the throttle, the car has a vibration in it. Can't really feel it through the shifter. If you get back on the throttle it goes away. The faster you go and let off of it the worse the vibration is.
U-joints are good
transmission mount is good
nothing loose
pinion angle is good
Everything seems to check out other than at the tailshaft where the driveshaft goes in. I push up on the driveshaft at the yoke and find that it moves some.
How much play should there be in the yoke at the transmission?
Any help will be appreciated.
Thanks,
U-joints are good
nothing loose
Thanks,
I would check the pinion angle like Barney Mobile said, could be the out put shaft bearing if there is a lot of play. what about under accel????
I have the same thing you are explaining and I have not been able to figure it out yet. There is a lot of good info in my thread though:
https://ls1tech.com/forums/gears-axl...tion-help.html
I think I will check tonight when I get home and make double sure the driveshaft is going in far enough. I put adjustable control arms on a while back and made them the same length as the ones that came off. But still going to check to see if that may be the problem.
Thanks for the help. Let me know if anyone has anything else to check.
