Clutch (race) recommendation for LS1
What clutch should i buy, itīs going to be only at raceuse. Drifting/Circuit, Engine is going to be hopefully 450-500whp NA and clutch should be quite light and come with flywheel (My engine is missing that)
So, recommendations?
As you may know we provide a number of clutches for those running D1 and Formula D. The biggest seller to guys planning for this type of use is the Stage 4. It is extremely light and takes a great deal of abuse. Most opt for the aluminum flywheel as well...though you could choose to run a steel too. If you wanted to go as light as possible you could also opt for our Aluminum pressure-plate option. Even with this assembly the set-up is very drivable for your planned use. Let me know if you have any further questions. Thanks!
We offer the 8" Mag Force for drifting and road racing applications. This unit comes in a 1 disc (500 ft tq) 2 disc (900 ft tq) and 3 disc (1500 ft tq) configurations. Call me if you have any questions.
