Havent seen this asked...replacement disc for Spec?
Right now I have a spec 3 that just started slipping. If the PP and flywheel look good, is it possible to buy only the clutch disc? If so, can a stage 2 be installed rather than a 3 and use the same PP? Or is there a difference between those? Thanks for any info.
BTW, right now I'm leaning towards the LS7 setup from SDPC but curoius if there is a less expensive alternative or if what I have goes in the trashcan. Not wanting a "race" clutch...been there. Looking for a smoother stockish setup.
I am in the same boat. My PP and flywheel look good, but the disk is almost worn out. I need to buy a 4+ disk only, but cannot find pricing on other than a complete clutch kit.
I guess monday Ill call them and see what they have to say. Anyone else have any tips?
Yes, you can buy discs alone from us. They cost 50% of the cost of the complete clutch kit. That being said if you all give me a call I will be happy to talk options and availability. I will need to know when you kits were purchased so I can insure that you get the appropriate disc thickness so having this info will make the process much easier. Let me know if you have any further questions. Thanks!
