ls1, ls6, ls2, ls7 slave cyl differances...
Old 09-18-2009, 02:53 PM
maxspeed96ct's Avatar
Default ls1, ls6, ls2, ls7 slave cyl differances...
Ive been doing some research and im tryin to figure out what differance is in between all of them..
I noticed the ls1 camaro and ls1 GTo salve has the same part number.
What about the ls2 GTO, is it the same slave as the ls1 ?
is the c6 vette salve better/diffrent then the GTO salve?
And most important are they all the same size and all interchangeable ?
as in a ls7 slave will fit in a ls2 or ls1 GT0 or ls1 camaro ?
Is one better then the other ? I assume the LS7 is best but what about the LS2?
Old 09-18-2009, 08:46 PM
well so far from what ive noticed all the vette slaves are interchangalbe bettween a ls1 ls6 vette and ls7 vette.
basicly you can run a LS7 slave in a LS1 vette or a LS6 or even LS2?
Am i correct ?
The camaro slave just looks like it has diffrent fluid lines..
Vette
camaro
Old 09-19-2009, 02:13 PM
bump, anyone?
Old 09-21-2009, 11:58 AM
Matt@SNLPerformance's Avatar
The C5, F-Body and GTO slaves are all the same except for the fittings. The C6 and LS7 slaves are completly different.
Give us a call and we can go over all the differences.
Matt
817-750-2000
Old 09-28-2009, 04:20 PM
Matt
817-750-2000
I dont want to waste your time calling.
Whats diffrent?
The fluid lines or is the size?
Quick Reply: ls1, ls6, ls2, ls7 slave cyl differances...
