T56 Carnage
Old 09-20-2009, 05:51 PM
the_merv's Avatar
Default T56 Carnage
About a week ago I posted the thread where I swapped my friends 2002 SCSB Truck from a Auto to a T56.
After the install and Hydraulics were bled we took it for a test drive to check everything out.
This was how it went..
1st: Smooth as butter..
2nd: Smooth aswell..
3rd: grinds like a bitch..
4th: same as 3rd..
5 & 6: shot to **** too..
Reverse: works fine.
So i start playing with it.. shifting slow while shifting it into 3, 4, 5, 6 when the Engine idled back down after I would push the Clutch in. I found them to go in smooth so that narrows that down right there to a Synchro problem.
Well my friend drove it around for a little bit and 3rd locked him out. I drove it and got it into 3rd with a little smack of the Shifter, so that made me think there is a problem with the Keys.
Today I tore it down to find this..
On the magnets there are all the Keys for the 3-4 Slider, and the 5-6 Slider. All the Pads on the 3-4, 5-6, and the Reverse Forks were like the ones pictured there. the 1-2 Fork Pads were intact, stock plastic. I found the reason the keys had come out to be that the Springs on the Sliders were installed incorrectly.
Also there was enough RTV in the Tranny to seal 6 of them with..RTV was everywhere..
The Input Shaft was loose as hell too..it was improperly shimmed.
I found Carbon Fiber Synchros in the Tranny aswell, suprisingly they are still good so I'm holding on to them as a backup.
My friend ordered the Tick stage II Kit and I'm rebuilding it with that, and a new 3rd Gear cause it's trashed.
This T56 was bought from a member on this forum and said to be in "good working order" I'm going to get into contact with him and find out who built this epic fail.
Be careful what you buy guys..
Old 09-20-2009, 06:16 PM
IWGF's Avatar
Bummer dude. I think a partial refund is in order. I know if I was the seller (I would never sell junk though) I would be absolutely willing to shell out some of the money you just paid me.
Old 09-20-2009, 07:02 PM
the_merv's Avatar
I don't have the guy in my feedbacks so I'll have to look through my old posts to find him.
I'm not too worried about it.. I can rebuild this into something nice.
I'm just takin someone's junk and making it right..
Old 09-24-2009, 10:48 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
I get lucky and only have to do reverse gear....for now. Good luck man. hard parts are $$$
Old 10-09-2009, 08:31 AM
the_merv's Avatar
Well I re-asembled it and found even more damage to this thing..
Inbetween the Case Seams where you RTV it there was little bits of metal squished in there, they looked like little bits of Gear Teeth. I guess whoever built it RTV'd it and they got stuck in it before the Case was slid on. I honestly want to find who built this thing and ask them WTF..
I cleaned them out and cleaned everything up and ground down any of the raised parts before it went back together.
As far as it running now..that thing it smooth as butter..the smoothest T56 I've ever driven in my life. When you are going along it feels like the Shifter sucks itself into each Gear.
I'm looking forward to the one that I built for my Camaro.
Old 10-09-2009, 09:00 AM
Pontiacerator
RevGTO's Avatar
Love the description. Great feeling when it's working "oh so right." Good job.
Old 10-09-2009, 09:23 AM
the_merv's Avatar
Thanks. There really is no other way to describe it..lol
Best part of it all..I installed a Speed-Bleeder when I put it in, it took us a whole minute to completely bleed the system, no joke..
I hope my Car is the same way.
Old 10-09-2009, 09:38 AM
Haans249's Avatar
Oh yea, the remote bleeder is AWESOME.
Old 10-11-2009, 01:19 AM
z28camaro1996's Avatar
my t56 grinds in 3rd and 4th and pops out of reverse every now and then. and couple of times its locked in 4 gear but was able to work it loose. how hard is it to rebuild?
Old 10-11-2009, 01:24 AM
where would i get a decent rebuild kit?
Old 10-11-2009, 10:27 AM
the_merv's Avatar
It's not very hard to rebuild..then again I guess it depends on how much experience you've had messing with things..for me it was pretty easy.
I used the Tick Performance Stage II re-build kit for this one and the one I built for my car aswell. It's a very good kit, and they aswell as a few of the other T56 gurus here helped me out with any questions that I had along the way.
With yours it sounds like you have a definate issue with the Keys in 4th..and a Synchro issue in Reverse, or worn pads on the Fork.
Old 10-11-2009, 06:13 PM
Gen414's Avatar
I offer Rebuild kits as well if you decide to do it yourself. If you need someone to do it, we handle that as well.
If it grinds in 3rd AND 4th, then would say key or pad is the problem. Now, if it locks in 4th gear, then probaly key issue.
Either way, tranny needs to come apart to fix it....but does not sound like to bad of a problem, no.
Old 10-11-2009, 08:28 PM
its not to bad cause i can some time get it to go in smooth in 3rd. it only locked up a few times about a year ago. and i had it rebuilt by some one who only rebuilt t5 mustang trannys. i had to take it out 3times for him and it still is not right.
Old 10-12-2009, 01:32 AM
the_merv's Avatar
I'd be getting some money back then..
Old 10-14-2009, 03:30 PM
bmartin8's Avatar
Almost looks as bad as mine was. Only my trans didnt even have the magnents in there, and I needed a new 1st and reverse gear. All is great now tho!
Old 10-15-2009, 01:09 AM
the_merv's Avatar
Yea the guy that built this one RTV's the Magnets in there..I cleaned them up the best I could..wish they were the way they were supposed to be though.
Quick Reply: T56 Carnage
