T56 winding noise
T56 winding noise
i just started hearing a winding noise tonight on my way home... i cant figure out what it is... the winding sound's pitch get higher the faster you go... the transmission was rebuilt 4 years ago but has been in service for only 2 years... i just recently replaced the shaft seal in the back of the trans(about 3 months ago) bc it was leaking a bit... when i replaced the seal the trans fluid was full... i took a look at that tonight when i got home and it looked dry... any ideas of what it is?????
Well, noises are very hard to diagnose over teh net. since we can't obviously "hear" them.
That being said, it could be bearings on teh way out (low fluid level, or extreme high mileage, as MOST rebuilds do NOT replace bearings)
Could be gear mesh (excessive clearance)
Ujoints (you SURE noise is coming from tranny)?
Rear end (again, you SURE noise is from tranny)?
Noise in ALL gears (1-6 and reverse)?
ok so i checked my diff fluid level and it was fine ... but it was metallic gray and felt gritty but i didnt see anything in it... i just had it rebuilt a year and some change ago too... is that the bearings in the diff going bad then????
Thats certainly what it sounds like to me. How much metal was on that magnant off the rear diff cover?
yeah, that is not a good sign. Change the fluid, pop teh cover off and then you will be able to see how bad it REALLY is, and report back...
Yeah, more than likely...
Very good possibility...
my car has that whining noise as well. but i think its my belts or the fuel pump. cause when its at an idle it does it in neutral in idle. when i drive it tends to get a bit louder the whining that is, so its either my belts up front or my fuel pump.
so... my trans (t56) just started making this noise as well but it is only 5th and 6th gear... and it is intermittent. I can make it go away by shifting 4th and then back to 5th or 6th again. There is some random clunking under load associated with the whine noise. is this time for a rebuild?
make sure the clunking noise is realy the tranny. it can be the mount going bad. or the y hititng the floor.
