What clutch?
What clutch?
Ok I'm tired of going through clutches. I have a Procharged stroked 408 with a P1SC with a T-56 and 4:10 gears. I havnt dynoed yet, so not sure the power I'm making. What clutch should I buy? Spec 3 with Spec aluminum flywheel or is that not enough? Do I have to go with a twin disc? I'd hate to have that much more weight added. Any insight would be very helpful. Thanks!
SS, what kind of torque are you planning to make? Let me know and I will be happy you provide a suitable recommendation. Remember, Stage 3 isn't the highest stage single-disc available. It may be that your ideal set-up is a stage 3+. Let me know a bit more and I will be happy to assist you further. Thanks,
A Stage 3 would handle this power but I would still recommend the stage 3+ for better drivability and even higher capacity. Because the Stage 3+ provides a more progressive engagement it will typically provide better wear when driven on the street. Give me a call if you want to place and order and I will be happy to assist you. Thanks!
Monster Level 3. We can get you hooked up with a standard weight SFI billet fly, or a lightweight version if you want.
You can call/pm/email... or check out:
http://www.morrismotorsports.net/mon...hes_levels_i-v
Thanks
Thanks
