PICTURES of measuring for shim, and bench testing setups, good tech....
Old 03-02-2015, 10:35 AM
  #61
SNLPerformance's Avatar
Originally Posted by badazz81z28
What is the typical distance to disengage a clutch? What many haven't considered, but really brought to light by Steve is the steel bellhousings with the block plates. This could reduce the cushion by .120"
Typically it's 0.250" to release a GM clutch fully.
Anytime you use an aftermarket bell housing you'll more than likely have to shim the setup because of that.
Quick Reply: PICTURES of measuring for shim, and bench testing setups, good tech....
