How to hold Flywheel when torqueing
How do you guys hold the flywheel when torqueing it. Do you put a another wrench on pulley end of the crank? I do not have my starter on right now so I cant put something in the teeth.
Use a second set of arms
I have my brother hold the nut on the balancer (up front using a 1/2 drive ratchet) while I use the torque wrench in back...
I bought the flywheel turning/holding tool from NAPA. I was able to remove clutch without taking bellhousing off. It also holds flywheel so you can torque the bolts. It is a good investment for $40.
