When putting the car in Reverse it goes forward?? - LS1TECH
Thread Tools Search this Thread
Old 11-22-2009, 12:19 PM   #1
CJDZ24_Z28's Avatar
Question When putting the car in Reverse it goes forward??
I have never had/heard of this happening. Car moves forward when its in Reverse. Any help would be appreciated
CJDZ24_Z28 is offline   Reply With Quote
Old 11-22-2009, 01:36 PM   #2
jam01's Avatar
not being a smart ***, are you sure your not putting it in fifth.
jam01 is offline   Reply With Quote
Old 11-22-2009, 01:51 PM   #3
the_merv's Avatar
X2..it's in 5th. Push it over more..check the fuse for the Rev. Lockout..it may be blown.
the_merv is offline   Reply With Quote
Old 11-23-2009, 08:55 PM   #4
CJDZ24_Z28's Avatar
i checked the engine fuse and swapped the fuse and still no go. i got it into reverse once and it took alll my strength. any other suggestions?
Old 11-23-2009, 09:41 PM   #5
NVR_SPDS's Avatar
Did it just start suddenly, or has it happened before, and just got worse? Really sounds like your only getting it into 5th.
NVR_SPDS is offline   Reply With Quote
Old 11-23-2009, 10:38 PM   #6
01ssreda4's Avatar
I have seen what it takes to defeat a reverse lock-out solenoid. Both arms!!
01ssreda4 is offline   Reply With Quote
Old 11-24-2009, 08:00 AM   #7
the_merv's Avatar
One arm here, and with a Short Shift..
Old 11-24-2009, 08:12 AM   #8
Rockerator
PewterScreaminMach's Avatar
Get under the car and check the plug for the reverse lockout on the transmission itself. Mine was unplugged at one point, as well, and it took both arms to pop it over into reverse, but it would go in if you pushed hard enough. It's possible your plug came unplugged. Do any hard launches/shifting/slamming of the car recently or were you working under there at all? I actually just forgot to plug mine back in once after pulling the transmission. Just an idea.
If the car is in reverse, there is no way it will move forward. It's not mechanically possible.
PewterScreaminMach is offline   Reply With Quote
Old 11-24-2009, 08:50 AM   #9
dschmittie1's Avatar
Yeah check the connector had a buddy that when he plugged it back together it bent a terminal over and made it very difficult to put in reverse.
dschmittie1 is offline   Reply With Quote
Old 11-26-2009, 02:42 PM   #10
CJDZ24_Z28's Avatar
Thanks i will be under there this weekend. Does anyone have a picture of it from under the car so i know what im looking for? I have installed lt headers,wps etc even helped remove a buddies T-56 but dont recall what the hell it looks like
Old 11-28-2009, 09:59 AM   #11
the_merv's Avatar
Its that bronze thing in the lower left corner in this pic..on the left side of the Shifter Housing..
Old 11-29-2009, 04:27 AM   #12
ruble50's Avatar
I just installed a moser 9 in and everything seemed to be working fine till all of sudden i thought i was going forward when in reverse just like the OP, but then found out i had to force it into reverse and i was actually in fifth. found this thread just went to the garage and found an unplugged wire. should be the reverse lockout one. i couldnt quite see where to plug it in with the car on the ground but ill jack it up tomorrow and plugging it in should solve my problem.
ruble50 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
4l80e reverse but no forward rp0029 Automatic Transmission 0 07-31-2012 06:02 PM
Freshly rebuilt tranny makes clicking noise, no D or R brianfromhawaii Automatic Transmission 9 07-12-2010 02:23 PM
cluctch or transmission problem HELP! vatechguy3 Manual Transmission 7 10-26-2009 06:56 AM
Gets stuck in reverse, although shifter not IN reverse Purple95Z28 Manual Transmission 4 10-08-2008 10:30 AM
rear end locks up when going in reverse? 383camaroSS Gears & Axles 4 09-17-2007 07:23 PM
Tags
95, camaro, car, club, forward, foward, gears, lockout, manual, moves, put, puts, putting, reverse, transmission, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
