Sticky gears at high RPM shifting
Old 12-03-2009, 04:47 AM
khenry's Avatar
Default Sticky gears at high RPM shifting
I'm having problems stabbing gears at high RPMs (mostly 3rd), and I've heard that the problem would be in the master cylinder if the pedal was sticking to the floor, but it's not. Low RPM shifting the car shifts fine. I recently had new gears (first and second) and syncros installed allong with a new clutch.Thanks for any help!
Old 12-03-2009, 01:08 PM
khenry's Avatar
Will a new master cylinder help with this?
Old 12-03-2009, 03:45 PM
RacingTiger03's Avatar
look into the drill mod A google search for LS1 slave cylinder should turn up the results you are looking for. I found a great article on it last night.. if I run across it again I'll link it for you.
Old 12-10-2009, 02:11 AM
ls1 1990 VN's Avatar
Thumbs up
Fit a new shifter, i had the same when racing i couldn't select 3rd, normal rpm was fine...fitted a MGW shifter and alls sweet now
Old 12-10-2009, 10:13 AM
99FormulaM6r's Avatar
I agree with the drill mod, from what I've read it looks like it should help!
Old 12-10-2009, 10:52 PM
Gary Z's Avatar
I don't think the drill mod will solve your problem. If bled properly, the clutch will disengage just as quickly without the drill mod. What clutch do you have? A disc with high rotational inertia can cause synchros to crunch at high-rpm. I have a Spec 4 clutch and shift smoothly at 7k. The Spec 4 disc has much lower rotational inertia than, say, a Spec 3+ disc.
Old 12-11-2009, 07:26 AM
1slowM6's Avatar
do you have longtube headers?the heat maybe boiling your clutch fluid....you should call tick and tell them you need everything to solve the problem....it works...ive done it. good luck...and pm me if you need more help
Old 12-11-2009, 09:10 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
So here is the break down. Say your fluid is old or boiled because it got to hot, making it old, then when you press the clutch pedal this fluid is still strong enough to diengage the clutch through the slave clyinder. When the fluid gets hot (like at high RPM runs) the slave gets hot, when the slave gets hot it expands, when this happens it "sticks" in the housing its in. So it works when its cooler but when the old fluid gets hot it becomes worthless.
Old 12-11-2009, 09:40 PM
David_viny's Avatar
Def bleed the hydraulics first just in case! Mine was reaaaal dark when I first got the car. I did it the easy way, siphoning the reservoir and filling it with new fluid. Takes several times to get it clear as it is just diluting the old stuff. But it beats actually bleeding the system.
In the summer I was doing it once a week after getting it fairly clean. Siphon and replace fluid, drive it for a week, repeat. Now its clear as new!
