Shifting problems, hard to get in gear.
When I bought the car, less then 6 months ago, it shifted fine. Only problems were the famous clutch pedal sticking.
After bleeding it several times, with no real progress. I put a new "luk" master in, gm slave, rather the dril mod I installed a steel braided line.
From what I can remember, it's gotten worse since I did that. I now have trouble getting it into gear, first, second, 0r reverse. Mind you, this is all at a stop.
I do have a b&m ripper shifter.
Suggestins or thoughts? I plan on thoroughly bleeding the system. Or is it possible that I installed he shifter just a hair off from where it was before?
Thanks
Thanks
