Interchangeable slaves?
Do G.T.O and F-body clutch slaves interchange other than the lines??I have a new g.t.o slave and an old f-body slave.Trying to save money if I can.The trans is in a 55 chevy so I have to make lines anyway.Thanks can't wait to drive this thing!!
Here's a good discussion, although you may need to do this a little differently since you are modifying the gto slave to fit the f-body trans. Good luck.
http://www.ls1gto.com/forums/showthread.php?t=273642
