Forward Mounted Shifter install problem
Old 12-21-2009, 09:48 PM
Formulized94's Avatar
Default Forward Mounted Shifter install problem
What friggen drill bits are to be used when drilling the shift rail? I have burned up four bits so far.
Any help is appreciated.
-Ryan
Old 12-23-2009, 09:47 AM
e-racer-ls-1's Avatar
Default Drill bits.
The outside might be hardened.Try taking a grinder and making a flat spot to drill on.It will take the harden part off and give a flat surface to drill.Just my 2 cents.Good luck
Old 12-24-2009, 11:13 PM
Formerly darynC-10/23/10
Daryn's Avatar
use carbide bits they are a harder material than hss bits
Old 12-25-2009, 04:54 PM
2 carbide bits later....lol. Thanks guys
I have another transmission to do this to, and I am going to grind a flat spot into it.
Old 12-30-2009, 09:16 AM
custom 68's Avatar
What kit did you use? I have thought about this but didnt want to take my tranny apart.
Thanks
Dave
Old 01-02-2010, 10:38 PM
I bought the kit from www.thegearbox.org
