trans mount
Old 01-01-2010, 11:24 PM
southpaw0314's Avatar
Default trans mount
i just completed a m6 swap, it seems fine under slow acceleration but as soon as i get on the throttle it seems that the transmission move a pretty significant ammount from the torque. is this normal? if its not the mount what else could it be?
Old 01-02-2010, 01:18 AM
Spartan7's Avatar
The shifter is going to move a little, you're not used to it yet. But if you just completed the swap, you should have been able to tell if the mount was broken. Usually when you get on it, the tranny with smack the tunnel.
Old 01-02-2010, 10:51 AM
thanks it doesnt do that. i appreciate it.
