Quick T56 Compatibility Question
Hello guys and gals, I've just got a quick question.
Will a T56 from a 2002 Z28 Camaro work with an LM7 (5.3L block from a 2000 Silverado)?
Will I have to change the bellhousing and/or the output shaft?
Thanks in advance!
Thanks in advance!
I think you'd be fine with an ls1 f-body tranny. I'm not positive but I think the only LS t56 tranny that has a little bit different output shaft (longer or shorter I forget which) is is the one from the the 5.3L SSR
