03 cobra short throw into 98 camaro?
Old 01-05-2010, 06:40 PM
98psymgnt's Avatar
Default 03 cobra short throw into 98 camaro?
as title says, friend of mine has a pro 5.0 short throw shifter out of an 03 cobra and i was wondering if it would fit into my 98 6 speed and what, if any, mods i would have to do to make it fit. thanks.
Old 01-06-2010, 02:18 AM
Bones Z28's Avatar
If he's a buddy I say he should let you try to hook it up and see if it works. I know those cobras have T-56s but that doesn't necessarily mean it will work. As I'm sure you already know a LT1 t-56 is different from the LS1 t-56, I would figure there is a difference in the Cobra. Hopefully someone can chime in who knows for certain.
Old 01-06-2010, 02:56 AM
c5formula's Avatar
The only difference between the lt1 and ls1 t-56 is the bell housing and the input shaft thats it. you can use a shifter from an ls1 car on an lt1 car and vise versa. now for the cobra t-56, the base should be the same but the handle is gonna be different as the mustang handle is cocked back some to more easily reach the driver.
Old 01-06-2010, 10:16 AM
itslow's Avatar
The shifter base is completely different between the GM, Ford, and Dodge versions of the transmission. It will not work.
Old 01-06-2010, 10:37 AM
calhoon's Avatar
Almost right. The '03-04 Cobra( Terminator) and Viper SRT-10 Ram T56patterns are the same. The extension castings differ, but the shifter base patterns are the same. The GM/ F-car shifter patterns are different and exclusive. Converion is not practicle.
Old 01-07-2010, 12:47 AM
98psymgnt's Avatar
thanks the replies all, i was at his shop earlier today and we tried throwing it in there to no avail. oh well, 120 hurst off ebay here i come
Quick Reply: 03 cobra short throw into 98 camaro?
