t-56 reverse problem?
maybe someone can help, im new to the t-56, i just put a 97 t-56 behind a carbed motor, everything is fine except sometimes it wants to pop out of reverse, it doesnt seem to want to go all the way into reverse. any one had this problem. maybe the shifter is messed up? going to try a new shifter
oh, and there is no electronics hooked up to it other than the speedometer, what does the skip shift solenoid do, and could this be something to do with the reverse, there is nothing hooked to this sensor.
yea i took that off and it made no difference, so i put it back on, so i wont go 4th to reverse. it rode in the back of my truck home for two hours with a lose shifter, maybe it bent the shifter? could a wore out shifter cause this?
seems to be a pretty common problem. if it is internal, than it's most likely a worn brass reverse blocker ring. I have the same problem and you can check out my thread https://ls1tech.com/forums/. I'm actually planning on replacing the reverse parts in my trans tomorrow. Hope that helps!
your shifter could possibly be the problem but its probably the brass ring inside the tranny. Which wouldn't take you long to fix after you dropped the tranny. You wont have to disassemble the whole thing unless you want to do a full rebuild on it.
PS mineola is by Tyler
