Need to find a fluid reservoir for the Master Cylinder
Old 01-06-2010, 01:15 PM
98RedBird's Avatar
Default Need to find a fluid reservoir for the Master Cylinder
I posted this up in the WTB section as well, but I accidentally gave my Fluid Reservoir away when I sold the stock clutch assembly. I got the Tick Master Cylinder installed and need a new one. I called the local junkyards with no luck. If you guys have one or know of anyone that has an extra let me know...
Thanks!
Old 01-06-2010, 01:24 PM
98RedBird's Avatar
I found two on Ebay, one is off of a 97 Z28 and another is a new universal T5 T56 Reservoir... Will either of these work?
Old 01-20-2010, 12:00 AM
The Big Shuck LS1's Avatar
I have one on my current master but I don't know how soon I'll get to installing my new gm master. I'll pm you when I have it off. Just pay for shipping. I really don't have a time frame though as to when I get to the job unfortunately.
Old 01-20-2010, 08:05 AM
85MikeTPI's Avatar
As long as the reservoir is resistant to brake/hyd fluid and seals against moisture, it should work.. Also remember that the hose line has to be brake fluid resistant (normal rubber hose is not). I've seen installs where a nice billet motorcycle brake reservoir was used for the clutch reservoir..
Quick Reply: Need to find a fluid reservoir for the Master Cylinder
