cant downshift into 2nd
ok when down shifting at any rpm my tranny will not go into 2nd gear. Ive tried tappin the throttle and all things like that. The only way to get it to downshift to second is to first shift into another gear like 4th or 1st without letting the clutch out and then it goes easily into second gear.
also the shifter seems to be unusually far to the right.. what could be causing this?
Location: Holmes County (thats right Amish Country), OHIO
1 Post
Mine does everything yours does except the far right part. I guess I just learned to drive with it. I can get mine to go in if I push the clutch in pull the shifter to the left then let the clutch out the press the clutch and put it into 2nd. I usually find it easier and faster to just put it in 1st then second to down shift. I can however downshift at like 38 MPH. If I have the clutch in and put pressure on the gear shift pulling it towards second then when it hits 38 then it falls in. Or I just rip it towards second while racing and just force it in. Thats probably not good for it.
