downshifted from 5th to 4th ,no sound or smell now no gears at all
i have a 98 ta built 383 ,ls7 clutch the car has ran fine since the swap 2 yrs ago , ive put around 20k on it since then , i was on 95 downshifted didnt hear or smell anything , nothing car just revs , the trans was fine no popping out,grinding,the clutch pedal still has the same pressure it always has , i put it in gear let out clutch and looked underneath the shaft isnt moving ? any suggestions before i start tearing out the trans ?
yes that is excatly what is happening , ive owned this car since it was knew so you can take my word for it ,when i say its in gear any gear ,even reverse ive only had the car at the track 3 times since i built the engine , and the first time out i had 3k on the setup with a spec stage 3 smoked it after 2 passes . i dont know what is going on here ,but i guess im gonna find out ! thanks
yea,
i kinda knew that was most likely what happened ,i was just hopin one of you guys would tell me that it was something simple,where the trans didnt have to come out , well you wanna play u gotta pay, but it sucks ! thanks again
