Master cylinder problem??
After i got my car tuned for the new motor i started to have a problem with the trans. I can shift 1st and 2nd fine, but if i run into high rpms in 3rd or 4th the clutch gets heavy, and wont shift into any gear. I have to pump the clutch a few times to get it to go into a gear. Is this a MC problem or is this someting else? This week im going to take the MC out and do the drill mod, heat wrap the line, and put in dot4 instead of dot3. Do you think this will fix the problem?
Honestly the drill mod is a band aid...been there with all the shifting issues. Clutch changes, bearings, slaves, and currently a Ram adjustable master.....soon to be getting the Tick Performance MC. As of now the car sits with bad syncros do to engagement/disengagement problems with the MC as the cause.
My advice get the Tick MC and save yourself the headaches!!
It might not be the master cylinder. I went though this a couple months ago and I was experiencing the same thing you are. Here's what happened to me:
New fluid (dot4) and a good bleed= helped a little
Drill mod= didn't help that much
New Tick master= helped a lot, but got worse over time. I had to keep adjusting it out.
New slave= didn't help that much
New clutch= shifts like a dream all the time. Bad pressure plate was the cause.
