T56 slave cylinder question
Old 01-25-2010, 10:02 AM
dynodanmanda79's Avatar
Default T56 slave cylinder question
I am installing a T56 in my LSX Iroc camaro, how do these slave cylinders work? does this look right to you guys? I see a notch on the side slave cylinder, but is the throwout bearing supposed to have a notch for it to slide onto? Thanks
Old 01-27-2010, 01:18 PM
TA_BUD's Avatar
Default slave
its ok dont worry about it, what clutch master will you be using, dont forget about the drill mod
Old 01-28-2010, 09:58 AM
I feel like a dumbass, all I had to do was push the throw-out bearing down so the notch on the slave cylinder would go underneath the plastic collar on the throw-out bearing. Anyways, I am running a RAM adjustable master cylinder for now, might go Tick later on. As for the drill mod, I bought the slave cylinder hose from a member here on LS1tech and he said that the hose was never drilled for the drill mod, but I can move an 1/8th in. bit into the line without any restriction. My guess would be that it was already done but I'm not sure.
Old 01-28-2010, 07:08 PM
jeepers_88's Avatar
**** on the drill mod!! it didnt do jack for me. The tick is incredible
Quick Reply: T56 slave cylinder question
