Changing fluid in a higher mileage T56 with gear grind
My 98 Z28 has 128k miles on it. The trans has trouble getting into gear (it grinds in first, second and sometimes 3rd) so I am going to adjust the clutch, flush and bleed the hydraulics, and change the trans fluid.
I don't know if the fluid has ever been changed in it, so the question is should I stick with Dex 3 ATF, a name brand synthetic Dex 3 ATF, or use GM Synchromesh?
I bought the car with the gear grind problem. The guy told me the clutch was just changed in it so I don't know if it just needs an adjustment or what not but I will be changing the fluid and give it an adjustment to start. Any guidance would be appreciated.
don't run synthetic with paper linings! it is to slippery, and will cause gear grinding, if they are carbon fiber like mine are now, after I rebuilt the transmission then you can run synthetic if you want, mine is super quiet and shifts great, I use regular ATF 3. Rebuilding the transmission isn't to hard especially if you don't do the bearings, I rebuilt my entire transmission bearings and all, and I sharped the cogs on second gear, plus new 2-3 sychro, shifts like butter! Now if I could only get the clutch to work properly
Thank you for the info. I want to try the BG products we sell at my dealer. BG DOT 4 Brake Fluid Ultra-Dry Flushing Formula for the flush. I think I will stick with the regular Dex 3 ATF for the trans fluid replacement.
