New Clutch Suggestions
Old 02-09-2010, 09:03 PM
navygoat's Avatar
Default New Clutch Suggestions
I have an 05 GTO and why my clutch is not yet slipping I know that it will be shortly. I also plan on doing heads and cams within the next year or so. If you have any suggestions for a performance clutch I would like to hear them as I am fairly new to the car and the general performance car side of life. Thanks.
Old 02-09-2010, 10:28 PM
bigj2717's Avatar
Check out monster clutches
Old 02-10-2010, 11:13 AM
Gforce Engineering's Avatar
The Level 3 Monster is very popular with heads and cam guys. It will hold up to 700hp so it give you some room to grow.
Here is the Level 3 on our web site if you want to read up on it.
http://www.shop.gforce1320.com/produ...&categoryId=21
The Monster clutch packages are a plug and play setup. It comes with everything needed for the install. Very well designed clutch packages.
Thanks
Chris
Old 02-10-2010, 12:16 PM
SPEC-01's Avatar
navygoat, aside from the heads and cams do you have any longer-term power goals. I ask because it's best to install a clutch that can handle your future mods. If you plan to stop with the next set of mods then a Stage 2 or Stage 2+ would be a great option. Of course, you could also opt for a stage 3+ if you plan to go bigger and better in the future. I have privided a link to our webpage specific to these parts below. Take a look and let me know if you have any further questions. Thanks,
http://www.specclutch.com/cars/Pontiac/GTO/2005/Single
Old 02-12-2010, 07:08 PM
navygoat's Avatar
Sweet, Thank you guys, I eventually would also like to get a blower but that will be a little while off. I will look those up and figure out which one I will need I am hoping to have a new clutch in by May
Old 02-15-2010, 11:26 AM
SNLPerformance's Avatar
One of our Monster's will definetly work out great in your car!
Give us or any of our dealers/distributors a call and we'll get you taken care of!
Quick Reply: New Clutch Suggestions
