Clutch Slave Cylinder hydrolic connection
I have a Clutch Slave Cylinder - AP D951004
What is the Gold hydrolic connector called.
Pictures can be found on reply 8 of the attached thread
https://ls1tech.com/forums/manual-tr...dentified.html
It is to go into a kit car.
Need to either get
- a standard hose with conntector attached,
- find out what connector is called and where I can buy one from so I can fabricate a hose.
- saw off the connetor and tap a JIC thread onto it.
Any help would be appreciated.
Regards
Kevin
Need to either get
Regards
Kevin
Kleeborp the Moderator™
The quick disconnect? It is held in place by a roll pin and seals with a small o-ring. I know someone makes adapters that will allow you to install a regular (or at least different) line and retain the same roll pin/o-ring fitting on the slave side - I got one when I bought a new hydraulic line from McLeod a few years back.
You might try giving McLeod a call, or call Tick Performance - they might have an idea of where to get the correct adapter fitting for that connection.
